ShroomcraftPvP
HomeHome  CalendarCalendar  FAQFAQ  SearchSearch  MemberlistMemberlist  UsergroupsUsergroups  RegisterRegister  Log in
 Question About a Map
SexyLlama
Bowman
PostSubject: Question About a Map   Sun May 10, 2015 9:15 am
I have been making a map that looks pretty good so far. One problem is that I am not very good with redstone, so i can't make anything open for a secret sign. Would any staff like to help me with my redstone problem?
TENNK001
Fighter
PostSubject: Re: Question About a Map   Sun May 10, 2015 11:04 am
I don't think redstone is absolutely necessary in order to hide a sign, there are plenty of other ways to include them into your map if you are clever enough.
If you still prefer to implement a sign hidden by a redstone, Good Luck.
Maybe look up a tutorial or something perhaps? Otherwise I guess you will have to wait for another staff member willing to help you with the redstone, as I am not really an expert in that area either.
BlueToast444
Assassin
PostSubject: Re: Question About a Map   Mon May 11, 2015 8:56 am
I am pretty good at red stone. Tell me what you are trying to do and I can help you.
SexyLlama
Bowman
PostSubject: Re: Question About a Map   Mon May 11, 2015 3:33 pm
I am trying to push a button and then a block opens up so you drop so you can get a sign. I think you need a piston
truthhurtsagain
Bowman
PostSubject: Re: Question About a Map   Mon May 11, 2015 5:24 pm
Okay, I'm going to tell you what you need to do for that, then you can discern how you want to hide it.
1. Place a sticky piston*** and have a redstone torch charging it (on the side of a block), then place the button where you want it and have redstone go from the button to the block that the torch is on the side of***, then the sticky piston should be touching (sticky side) on the block you want to move, then once the button is pushed the sticky piston will pull it back due to the redstone torch snuffing out since the block it's on the side of*** is charged, I hope this helps.
SexyLlama
Bowman
PostSubject: Re: Question About a Map   Mon May 11, 2015 8:58 pm
Thank you I will try to do it
ShroomcraftPvP :: Community :: Map Builds-
